Pipeline lowering-in calculations such as lift point spacing, number of sidebooms required
Who is an expert? What manuals, references, and or regulations should I be using. Equations = ?
RE: Pipeline lowering-in calculations such as lift point spacing, number of sidebooms required
I've had some luck using splines to predict the stresses that will form under various curvatures formed by lines bending under their own weight and passing through fixed support points. If you have the shape of a beam described as deflection vs distance, then by taking successive derivatives you can arrive first at curvature, then moment * EI, shear force distribution and lastly support loads. Do for each configuration as the pipeline is lowered into the trench.
This area is one which always confuses my offshore colleagues who study to death the installation forces on the pipe, bending moments, tension etc etc
Onshore you just make sure the machine won't fall over in the ditch and then the actual lowering is undertaken "by eye". If it all goes horribly wrong and the pipe gets bent, then you just lift it out, cut it out and put a new one back in - then get a new lowering in foreman or sideboom / crane / digger operator - whoever got it wrong.
I've never seen any reference or regulation specifically referring to lowering in, but if anyone appears I'll put it away for future reference.
Key aspects you can look at include a basic beam bending with multiple point loads to simulate the pipe being picked up by more than one machine - Usually minimum of three machines - with a check for bending stress, and local buckling check. Standard equations apply.
The next big check is weight capacity of the various machines at the lift distance required. ~This is what usually governs the number and type of machines. It's where the accidents happen when you exceed the capacity of the boom or crane. Big pipes with a wide trench are especially vulnerable. At full extension, the load capacity is about 25% of the "rated" or nameplate capacity. Hence it might start as a 30tonne machine, but at an extension of 7m, with counterweight out, reduces to approx. 7 tonnes.
This is a famous video showing what happens when you get it wrong - I think they blamed it on the wind, but I think they just got it wrong with weight or something collapsed at the far end.. https://www.youtube.com/watch?v=oOz5axLVJHE
This site seems to give a lot of info on a lot of different sidebooms / pipelayers for capacity charts - very useful. http://sidebooms.com/products/pipelayers/
There is actually an ASME spec for side booms ASME B 30.14 -2015 which defines the load rating and machine capability.
Pipelines become unbelievably flexible when you lift up enough length - usually 50-70m is enough to get the strain below 0.5% and well below SMYS.
Is there a reason for this or are you just curious??
