Hi all can anyone give me some info
Hi all can anyone give me some information on how to load test Land Rig Skids, problem is none of the units have a CoC, or data plate with Tare Weight, Max Gross Load, need to find out SWL of each unit
RE: Hi all can anyone give me some info
Not withput more information. No.
No photo. No descriptions, no sketch? No make, model, and serial numbers?
Lifting16,
Management used to have a note on the new-thread page that said something like "Enter a meaningful subject, "HELP"
is not meaningful". That was really good advice, and many of us will not open a thread with a title like "Hi all can anyone give me some info". I only opened it to point out to you that you are REALLY limiting the possibility of getting a solution by putting an worthless title on your thread, only to find that it is a worthless thread. Good luck with this.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Here it is - Scroll to bottom, click Posting Guidelines, and select the "Tips on how to write a 'good' question" link. I'll copy and paste it below:
How To Post A "Good" Question
Look Before You Leap: Use the FAQ page and the Search function before posting a question. Somebody may have asked and answered your question yesterday.
Think! Carefully word the title of the thread to reflect the problem. This makes it more likely to attract the attention of those who actually know the answer. It will also allow others in the future to find your question (and answer) by using the search engine.
Edit Rather Than Braindump: We're all busy people - please be respectful by taking your time to briefly specify the problem, question, and result you are trying to achieve. Include all details that might be helpful, such as background that may affect the problem/solution, solutions you've already tried that haven't worked (and why). Leave out any details or chat that won't help solve the problem, and address only one question/problem per post.
Programming Code: If including programming code include any exact error screens and only the smallest possible code sample that will illustrate your problem. Also, be sure to surround your programming code with the
CODE
tags. This tag will format your code in a monospace font as well as avoid possible conflicts with other HTML output.
Proofread: In terms of speed for those scanning many threads, spelling and grammar count! Make it easy for others by proofing your posts for typos, spelling, grammar, as well as clarity.
Follow Up: Be sure to mark the "notify me" box when you post. The system will send you a note if someone replies. We suggest you don't post your e-mail address as it only attracts sales people and recruiters to the forums.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
