24V /7 pines connector of a trailer
Hello all,
My question is I have a truck with a system of 2 batteries of 12V and I want to know if I can connect it to a tráiler connector of 7 pines of 24V for my brake system?
Can they match?
thanks in advance.
Can they match?
thanks in advance.
RE: 24V /7 pines connector of a trailer
The issue was that I had an american truck model and I had in fabrication an european/asian tráiler, so the european/asian trailer use a system of 24 volts. The solution just was change the european/asian 7 pines connector by an american 7 pin connector, where the only difference is in the voltaje.
