Multiple extrudes from one sketch_ New question
I have a question related to the following thread. My question is for Creating Extrude to make solid, it works fine, but while trying to create 'Subtract' from solid using intersecting curves (with 'Region Boundary Curves') it does not work and it is showing me an error as attached image. How can I solve these problem, there must be a solution for these. Thanks in advance for any suggestions.
http://www.eng-tips.com/viewthread.cfm?qid=305343#...
RE: Multiple extrudes from one sketch_ New question
It is difficult to tell what is going on in the screenshot. Can you upload an example file?
NX doesn't like it when you have regions that are touching at a point. I don't have a good answer how to solve your problem.
Windows 7
NX 10.0.3.5
