VACUUM TEST FOR SUBSEA POD
Hi Guys,
Need your help here. I have a subsea POD to operate at maximum depth of 3000mtrs. Because of restriction to use a test chamber for external pressure test, we decided to do vacuum test.
the problem is what should be the internal pressure for the pod?
FYI, the pod will contain no fluid.
RE: VACUUM TEST FOR SUBSEA POD
You can't apply a head of minus 3000 meters of seawater to the inside of the pod, because vacuum doesn't work that way. The most pressure you can apply to the outside by evacuating the inside is one atmosphere.
You need to build, buy, or rent the chamber to do the external pressure test, or just don't bother.
Mike Halloran
Pembroke Pines, FL, USA
So we can only assume that from your point - "..we decided to do vacuum test" that you meant to subject, somehow, the inside of the POD to a vacuum,
Otherwise the pressure difference is the wrong way.
This doesn't look very big, what is the "restriction" on testing??
Can't you build one from some large, thick pipe? Design pressure of 300 barg isn't that high.
What are you testing? The ability of the "POD" to withstand negative pressure or the seals or what?
Is this thing actually subject to hydrostatic pressure or does the POD fill with water?
lots of questions / unknowns
We have the test chamber actually, but due to other issues, the management insist on vacuum test.
I've spoken with someone who already did this test before. Basically what he did was just maximize the differential pressure between the internal and external.
I saw in his test report, the differential pressure is only 28-29 inHg (maximum value on the gauge). He only tested the seals integrity not the structural basically.
I appreciate all your replies and TQVM.
Actually, when you are using pressure-energized seals, e.g. o-rings, it is possible to have a seal assembly that will withstand several thousand psi, but will leak at a differential pressure of just a few inches of water. But a dp of one atmosphere is usually more than enough to energize the seal and stop the leak, so a vacuum of 29"Hg is not really the best test pressure for that purpose. I'm going to guess that your managers are thinking of other, other issues.
Mike Halloran
