RT1 or RT4
RT1 or RT4
Dear forum member,
I have a pressure vessel, one of the circumference seam is considered as Type 3 joint as per table UW-12. (Because we can't inspect the internal quality of the weld)
If i do 100% radiography on all the joint, can the vessel be categorised as RT1?
Wcw
Wcw
RE: RT1 or RT4
RE: RT1 or RT4
Regards.
RE: RT1 or RT4
My query is not about to make type(3) joint into type (1), my query is that "can type (3) joint comply to RT1 requirement?".
RE: RT1 or RT4
Regards.
RE: RT1 or RT4
RE: RT1 or RT4
RE: RT1 or RT4
RE: RT1 or RT4
Regards.
