NXCAM - flipping a non symetrical part on a vacuum table - new additional mcs or flip existing mcs?
Hi Guys,
I am doing a chamfer operation on a part that is on vacuum plate. I want to flip the part over (pins register it back in position) and do the same operation again on the reverse side. How do I go about this with regards to the MCS? What is the best way? I don't really want to flip the MCS over as this will of course effect previous and future
operations. Can I add another MCS and just use if for this single flipped chamfer operation?
cheers,
James
RE: NXCAM - flipping a non symetrical part on a vacuum table - new additional mcs or flip existing mcs?
You can have a different MCS for each side, and put the operations there in the geometry view, even though the operations are in the same program.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Hi Mark,
perfect, that worked. Many thanks!
James
