replacing CMU face shells - shear transfer?
I have an opportunity to help out a contractor friend. Without going too deep into why, they need to remove the face shells from an existing reinforced jamb and replace them with ground-face block (see attached photo). The EOR is concerned that doing so will create a cold joint and prevent compressive stresses from getting into the new masonry. I have analyzed the jambs for a smaller depth of reinforcing and they don't work.
Has anyone done anything like this? Is there an epoxy/adhesive/grout that will provide adequate bond to properly transfer the shear stresses? Plan B is to add a CMU pilaster behind the jamb to take the entire lateral load.
RE: replacing CMU face shells - shear transfer?
Plan B appeals to me, although I might consider a structural steel member instead of a pilaster.
BA
BA
