Does a part file "remembers" the license bundles it was created on?
Hi All,
Our customer sent us a part file, which contains features we haven't the license for. That means the model history tree contains some features, which I need to change or correct, but explore a license issue while trying to edit them. Is there a way to know which license bundles were used by the part author during its development?
RE: Does a part file "remembers" the license bundles it was created on?
Regarding your particular question, you could probably post the feature name (like Edge Blend, Studio Surface, etc.) and have someone give you a good idea.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
However, there are some recent exceptions, including the recently announced 'NX Realize Shape'. In this case, you have to actually be in the module to enter the task where the various editing tools are available. But once an 'NX Realize Shape' model has been created, you can still edit it like it were a non-feature-based free-form model. Of course that will require that you have access to tools like 'X-Form' and 'I-Form', but at least you won't need an 'NX Realize Shape' license.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
It would be definately no problem if the geometry was less complicated - it is a complex aerospace shape - hard to edit it using synchronous modelling. Anyway, will ask the customer to edit the part and send it once again.
www.CADabout.ru
