NX10 journal not showing dialog box
Hi All,
I'm trying to record a journal to display "derived curve - isoparametric curve" which has a green dot meaning it's a supported command. It records fine but when I try to play it back the dialog box does not display on screen. Nothing happens. Does anyone no how to get this working.
CODE:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
' Menu: Insert->Derived Curve->Isoparametric Curve...
Dim markId1 As NXOpen.Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim nullNXOpen_Features_IsoparametricCurves As NXOpen.Features.IsoparametricCurves = Nothing
If Not workPart.Preferences.Modeling.GetHistoryMode Then
Throw(New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
Dim isoparametricCurvesBuilder1 As NXOpen.Features.IsoparametricCurvesBuilder
isoparametricCurvesBuilder1 = workPart.Features.CreateIsoparametricCurvesBuilder(nullNXOpen_Features_IsoparametricCurves)
isoparametricCurvesBuilder1.Direction = NXOpen.Features.IsoparametricCurvesBuilder.DirectionTypes.IsoV
isoparametricCurvesBuilder1.Number = 2
isoparametricCurvesBuilder1.IsSpacingEnabled = True
isoparametricCurvesBuilder1.Spacing = 50.0
isoparametricCurvesBuilder1.Associative = False
theSession.SetUndoMarkName(markId1, "Isoparametric Curve Dialog")
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Rick D
Win7 64 bit w/NX9.0.3.4 MP9 and NX10.0.3
Vericut 7.4
RE: NX10 journal not showing dialog box
Journals do not display the standard NX UI dialog box of the command that you are running.
www.nxjournaling.com
Thanks Cowski,
Haven't done a journal in a while and think I forgot that they need a selection method and simple dialog from within VB. Now if I can only get the selection to work.
Rick D
Vericut 7.4
Do you need to select faces, or something else?
Hi Cowski,
Yes I need to select a cylindrical face (hole).
Rick D
Vericut 7.4
Below is one way to limit selection to cylindrical faces:
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module3
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
        Const undoMarkName As String = "NXJ journal"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim selFace As Face
        If SelectFace("Select a face", selFace) = Selection.Response.Cancel Then
            Return
        End If
        lw.WriteLine("face tag: " & selFace.Tag.ToString)
	if selFace.IsOccurrence then
	    lw.writeline("owning component: " & selFace.OwningComponent.DisplayName)
	    lw.writeline("component part file: " & selFace.OwningComponent.Prototype.OwningPart.FullPath)
	else
	    lw.writeline("owning part: " & selFace.OwningPart.FullPath)
	end if
        lw.Close()
    End Sub
    Function SelectFace(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a face"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_CYLINDRICAL_FACE
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selObj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thanks Cowski I will give it a try
Rick D
Vericut 7.4
Hi Cowski,
Got this to work. A bit messy but working
Rick D
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module3
Public selFace As Face
Public cursor As Point3d
Sub Main()
Return
End If
'lw.Open()
'Dim selFace As Face
Return
End If
'lw.WriteLine("face tag: " & selFace.Tag.ToString)
'if selFace.IsOccurrence then
'lw.writeline("owning component: " & selFace.OwningComponent.DisplayName)
'lw.writeline("component part file: " & selFace.OwningComponent.Prototype.OwningPart.FullPath)
'else
'lw.writeline("owning part: " & selFace.OwningPart.FullPath)
'end if
'lw.Close()
'MsgBox("Here")
Dim face1 As NXOpen.Face = selFace
Dim point1 As NXOpen.Point3d = cursor
isoparametricCurvesBuilder1.SelectObject.SetValue(face1, workPart.ModelingViews.WorkView, point1)
isoparametricCurvesBuilder1.UpdateIsoparametricCurves()
Dim nXObject1 As NXOpen.NXObject
nXObject1 = isoparametricCurvesBuilder1.Commit()
End Sub
'Dim cursor As Point3d
End With
selObj, cursor)
Else
End If
End Function
End Function
'End Sub
End Module
Vericut 7.4
