Exporting custom human with custom posture from Siemens NX
Hi
We are designing a product and we need to export custom human model from Siemens NX. Problem is that I am not able to succeed. I have tried all universal file systems yet all I can achieve is to get errors or corrupted exports.
This model is later imported to Solid Edge for reference.
I found one thread which could cover it and it was here in this forum, no answers given.
Best regards!
Best regards!
RE: Exporting custom human with custom posture from Siemens NX
If so - then try to switch to the History-Free Mode or (in newer NX versions) remove part parameters. After that human model will become a set of faces and bodies, which are suitable to export (STEP for an instance).
The other way - it works fine if export to JT file format.
www.CADabout.ru
