minimum thickness setting
I have the following query:
According to ASME code the minimum thickness UG-16 (b) should be 0.0625. "But I want to know if the software has the option to change this minimum thickness ?. For example setting the software to consider a minimum thickness of 6 mm.
RE: minimum thickness setting
Henry, look on the ASME Code dialog for the UG-16 Minimum Thickness settings.
Note, assuming that your company has current SUS subscription you would likely be better served contacting Codeware directly for technical support. My suggestion only.
