dynamic analysis abaqus
hello,
i'm modelling a steel frame and i'm tryng to do a dynamic analysis using abaqus. I did a implicit dynamic (I do not which is better explict or implicit). I was wondering if I have to imput the time history in g or in in/s2?. If i input in g the accelerations, should i multiply my result by 386,022?
thanks you.
thanks you.
RE: dynamic analysis abaqus
In the unit system you've used to define the other properties. So if you use mm,s,t as basis then gravity would be 9810.
thanks a lot for your help.
