Weld Repair and "E" value used in Head Calc
A small nozzle hole was incorrectly placed and repaired by using the material drop from the correct hole as the plug for the incorrectly located opening, and the weld was LP tested.
If the calculations were originally performed using a seamless ellip head with "E" value noted below...
Efficiency, Longitudinal Seam 0.85
Efficiency, Circumferential Seam 0.65
Do I have to change the Long Seam E value to 0.7 because of the weld repair?
RE: Weld Repair and "E" value used in Head Calc
r6155
Do you by chance have another section from the code that addresses why this isn't necessary?
r6155
Seamless: no seam it's not a segmented head. Openingse are to be compensated.
I did some searching and found Interpretation VIII-1-86-22. The status is Out of Date and notes that paragraph UW-34 has since been added, specifically addressing the closure of spin holes created by forming. It considers the welds to be unclassified joints, not to be considered for determining the "E" value for calulating the head thickness.
Which was my response to the AI, however the argument that the hole being repaired is in fact not a SPIN HOLE. Why does it matter how the hole got there, a hole is a hole, it's being plugged with the material ht# taken from the new hole, welded the same as required for a spin hole and LP tested the same as a spin hole.
Our problem is that the thickness requirement exceeds the actual min thick when we change the E value from 0.85 to 0.7, and the heads have to be scrapped. I'm trying to avoid this waste.
r6155
1) You can scrap the head
2) You can engage in a p#ssing contest with your A.I.
3) You can shoot the repair and get on with life.
Mike
I was aware of my options when I started this thread.
I simply needed to let them know if the heads were acceptable per the AI's request to reduce the "E" factor.
In the end it's on the Shop to deal with it, however I'm a "big picture" type person and was looking out for the Corporate bottom line.
Again thanks to everyone for your comments and suggestions
