Measuring Pipe wall thickness when using pipe for shell or nozzles on ASME VIII pressure vessels
For years we have checked our pipe wall thickness at receiving when the pipe is for pressure vessels. Does anyone else do this? How many measurements per pipe or lot do you use? What code references mandate this practice?
RE: Measuring Pipe wall thickness when using pipe for shell or nozzles on ASME VIII pressure vessels
I think that this practice is specified only on companies guidelines and project specs.
