Foundation Settlement, Sand over Silt
I have a project where I need to estimate settlement due to a six story structure. The general soil profile is 20 feet of medium sense sand over 80 feet of stiff silt. Best method? Thanks!
RE: Foundation Settlement, Sand over Silt
Modulus-based compression typically occurs as the load is applied. Post construction compression can be an additional 20 to 30 percent of the calculated value, depending on the design life.
f-d
ípapß gordo ainÆt no madre flaca!
It has been found quite accurate by Calif DOT, in non saturated soil but under estimates it about 50% in saturated soil.
"Compressibility as the Basis for Soil Bearing Capacity"., B.K. Hough
ASCE Journal of the Soil Mechanics and Foundation Division, August 19+59 , Number SM 4, 2135
