THICKNESS TOLERANCE MAY APPLY TO MEET THE PIPE SCH
Dear EXPERTS,
Good Morning,
we were Mistakenly Pre Insulated the CS PIPE(ASTM A 53 Gr.B ERW)of 12 Inch SCH STD Pipe Instead of Doing 12 Inch SCH 40 Pipe. So Can i Have the option to apply the Thickness Tolerance Here to meet the SCH STD Pipe to SCH SCH 40.
NOTE : Customer Required SCH 40 Pipe Only.
SIZE OD 323.9MM Thickness SCH STD = 9.53 mm and SCH 40 = 10.31 mm.
Thanks in Advance.
Good Morning,
Thanks in Advance.
REGARDS,
G.SRIRAM.
Dream,Dream,Dream Dream transforms in to thoughts.And thoughts result in action
RE: THICKNESS TOLERANCE MAY APPLY TO MEET THE PIPE SCH
I would think only if the measured thickness of the SCH STD meets the SCH 40 minus mill tolerance which I assume you mean by Thickness Tolerance. Even if this is the case customer will have to be consulted and accept.
as its ERW, it probably came in as plate, so should be a fairly uniform thickness.
However please don't try and hide it from the client - it needs to be submitted as a deviation request and expect it to be rejected.
Thanks to all for your Valuable Comments. We Rejected Customer Not ACCEPTED.
REGARDS,
G.SRIRAM.
