Edit the CCP Links ( Replace the Pointed Document in CATPart File)
Hello All,
Does anyone has an idea on How to replace the pointed document in CATPart using Code so, the links will get updated with the new Selected Part file.
My Team is working on CAA code to replace the Pointed Document in CATPart using API "SetExternalObject" available with CATISpecAttrAccess interface. Code works fine but does not replace the file in Edit Links. Its still pointing to the original document.
Satish
RE: Edit the CCP Links ( Replace the Pointed Document in CATPart File)
It is for CATPart to CATPart.
I can do the Link replacement between CATDrawing to CATPart.
