Group of ICAO certified Aircraft Warning Lights
Am searching for a group of ICAO certified Aircraft Warning Lights Enthusiased. Does anyone know of any group online or offline to know more about Obstruction Light rules, especially in India
RE: Group of ICAO certified Aircraft Warning Lights
I recall an extensive thread on this subject on Eng-Tips a few years ago. You might try the search function.
Keith Cress
Quote (moon161)
>>You could try and use a bottle jack to press the studs out. You could hold it down using the adjacent studs. <<
>> There is not enough room to press them out towards the bottom. Or am I misunderstanding your suggestion? Although maybe could potentially press it down enough to break it loose, maybe 1/2", then pull it back up. <<
However it works out. Breaking it loose is key. Time AND Load AND penetrant may work for you too. A bottle jack is something you can pump up and leave it be if it's not keeping something from falling on you.
@moon161 ... ?
@OP ... "Aircraft Warning Lights" I understand, but "Enthusiased" I don't get ??
Just lost in translation, RB.
Something you could only replicate if you could determine the OP's language, and force the right phrase thru google translate into english.
STF
