Feature Def Error
Feature Def Error
I am doing some surfacing and I am getting an error that I do not understand. It seems to only effect "Variable Fillet. Any help with this would be greatly appreciated.
Error:
Kevin
V5R22
Error:
"Feature Definition Error"
"In-Out Cycle detected in feature structure"
Kevin
V5R22
RE: Feature Def Error
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
I have attached a file, I get the error when I try to run a variable fillet. If I separate the surfaces I can use Shape Fillet without issue. After reconstructing a shelf I no longer had issues (Join.130)
Any help in understanding the error would be much appreciated.
Kevin
I would try to run a CATDUAV5 and check the list of the return code detected by CATDUAV5 , maybe you will find something there.
Fernando
I will try the CATDUAV5
