Anybody have experience with moment connections on rotated columns?
Currently, I'm thinking about a CJP weld for the top and bottom plates with stiffeners/continuity plates. Anyone have any better ideas or comments? I attached what this looks like.
The column is ~5 degrees rotated from the beam.
RE: Anybody have experience with moment connections on rotated columns?
I'm curious about how they dealt with torsion in this analysis. Was it treated as self-limiting and allowable, or is it taken out with bracing somewhere? I'd be worried about the stability implications of a lateral system that puts torsion on what is presumably part of the gravity system. You could have some exciting torsional buckling problems.
My concern with an endplate connection is that if the beam is cut at an angle, the ends of my flanges won't have enough area to prevent yielding/rupture, that's why I want to continue the flanges through the column.
I don't understand this concern. At a skew, would you not have more connected material than you would without the skew? Either way, 5 degrees isn't much more than naturally occurring field tolerance. My one and only concern in a non-SMF would be constructability. Is there a contractor on board who can expressss a connection preference?
