Hi I want to use this journal to
Hi
I want to use this journal to list part attributes that have 'reference text'
linked to theme. can someone help ? which nxopen function to use ?
I mean a 'reference text' that builded this way:
In drafting I open the Note Dialog and click the Insert Part Attribute icon and I select an attribute
and that create This <WRef1*0@Title1> on the dialog and the 'reference text' on the graphics window.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module show_part_user_attributes
Sub Main()
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim markId1 As Session.UndoMarkId
markId1 = s.SetUndoMark(Session.MarkVisibility.Visible, "Report Body Attributes")
lw.Open()
ufs.Ui.ExitListingWindow() ' Clear and close the window
Dim ndx As Integer
Dim attrInfo() As NXObject.AttributeInformation
Try
attrInfo = s.Parts.Work.GetUserAttributes()
For ndx = 0 To attrInfo.Length - 1
lw.WriteLine("Title = " & attrInfo(ndx).Title & " Value = " _
& attrInfo(ndx).StringValue & vbCrLf)
Next
Catch ex As Exception
MsgBox(ex.ToString(), MsgBoxStyle.Critical)
End Try
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
Thanks in advanced
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Sub Main()
lw.Open()
Dim ndx As Integer
Try
Next
End Try
End Sub
End Function
End Module
Thanks in advanced
RE: Hi I want to use this journal to
www.nxjournaling.com
Meanwhile till your post I found a class that deal with this
AssociativeText and with Google search I found a little
Help to make me start
Thank you for this post
OK I'l post back with my results
But for now you can see the class in this link
https://docs.plm.automation.siemens.com/data_servi...
This line was the key for me to know how to use the methods of AssociativeText class
at = wp.Annotations.CreateAssociativeText()
I found this help in the line
Annotations::AssociativeText *theAT = workPart->Annotations()->CreateAssociativeText();
in this site
thread-3653: Architectural Layering Standards-1-1.html" target="_blank">http://www.plmhome.com/thread-3653: Architectural Layering Standards-1-1.html
And after playing with the method
found = at.GetPartAttribute(t1, attTitle)
I found that if an AssociativeText is a standalone found = true so in this case all is OK
but if a line is like this
"start with regular text <WRef6*0@DB_PART_REV> end with regular text"
found = false
and finaly a surprise if a line contains a regular text but start with an AssociativeText like this
"<WRef6*0@DB_PART_REV> additional regular text"
the found return true.
so the solution is the folowing linse.
For s1 = 0 to textLine(tL).Length - 1
t1 = textLine(tL).SubString(s1)
The journal can be used to edit drafting decall that based on AssociativeText
************* the code start here need NX853 *******************
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI.NXInputBox
Imports System.Collections
Module edit_associativetext_for_note_or_label
Dim ui As UI = ui.GetUI()
Sub Main(ByVal args As String())
Dim wp As Part = s.Parts.Work
Dim new_string As String
Dim old_string As String
Dim obj As NXObject
Dim cursor As Point3d = Nothing
Dim textLine As String()
Dim attTitle As String
Dim tL As Integer
Dim resp As Integer
Dim s1 As Integer
Dim t1 As String
Dim aNote As Annotations.NoteBase
Dim found As Boolean
Dim atLeastOne As Boolean
Dim alreadyProcessed As Hashtable
Dim at As Annotations.AssociativeText
alreadyProcessed = New Hashtable
lw.Open()
While SelectNoteorLabel(obj, cursor) = Selection.Response.Ok
aNote = obj
textLine = aNote.GetText()
alreadyProcessed.Clear()
For tL = 0 To textLine.Length - 1
atLeastOne = False
If textLine(tL) = "" Then Continue For
Try
If found = True Then
atLeastOne = True
If Not alreadyProcessed.Contains(attTitle) Then
alreadyProcessed.Add(attTitle, attTitle)
old_string = wp.GetStringUserAttribute(attTitle, -1)
new_string = GetInputString(attTitle & " : Attribute Value", _
at.GetPartAttributeText(attTitle), old_string)
If new_string = "" Then
resp = ui.NXMessageBox.Show(textLine(tL), NXMessageBox.DialogType.Question, _
"Delete " & attTitle & " : Attribute Value ?")
If resp = 1 Then
new_string = ""
Else
new_string = old_string
End If
End If
wp.SetUserAttribute(attTitle, -1, new_string, Update.Option.Now)
End If
End If
Next
msgbox(ex.ToString())
Continue For ' ?
End Try
If atLeastOne = False Then msgbox(textLine(tL) & vbCrLf & vbCrLf & _
"This is not an AssociativeText object")
Next
End While
End Sub
Public Function SelectNoteorLabel(ByRef obj As NXObject, _
ByRef cursor As Point3d) As Selection.Response
Dim mask(1) As Selection.MaskTriple
mask(0).Type = NXOpen.UF.UFConstants.UF_drafting_entity_type
mask(0).Subtype = NXOpen.UF.UFConstants.UF_draft_note_subtype
mask(1).Type = NXOpen.UF.UFConstants.UF_drafting_entity_type
mask(1).Subtype = NXOpen.UF.UFConstants.UF_draft_label_subtype
Dim resp As Selection.Response = ui.SelectionManager.SelectObject( _
"Edit AssociativeText for example <WRef6*0@DB_PART_REV>", _
"Select Note or Label to edit", Selection.SelectionScope.WorkPart, _
Selection.SelectionAction.ClearAndEnableSpecific, False, _
False, mask, obj, cursor)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
I copy paste its contains
Point* getCompPoint(Assemblies::Component* comp, string name){
Point* pnt = NULL;
Part* prt = NULL;
tag_t occ = 0;
Features::FeatureCollection* fc;
prt = dynamic_cast<Part*>(comp->Prototype());
if (!prt) //Prototype der Komponente nicht gefunden
return NULL;
//Features des Parts durchsuchen
fc = prt->Features();
for (Features::FeatureCollection::iterator it = fc->begin(); it != fc->end(); ++it){
if (!strcmp(name.c_str(),(*it)->Name().GetLocaleText()) &&
!strcmp("POINT",(*it)->FeatureType().GetLocaleText()))
pnt = dynamic_cast<Point*>((*it)->GetEntities().at(0)); //Punkt des Features im Part
break;
if (!pnt) //Punkt im Part nicht gefunden
return NULL;
occ = UF_ASSEM_find_occurrence(comp->Tag(),pnt->Tag());
pnt = NULL;
if (!occ) //Punkt in Komponente nicht gefunden
return NULL;
//Punktobjekt vom Tag generieren
NXObjectManager* objM = new NXObjectManager();
pnt = dynamic_cast<Point*>(objM->Get(occ));
delete objM;
return pnt;
