Meshing an irregular part in Abaqus
I want to model a pile penetrate into soil media and have a problem with meshing the model. I always get an error saying the elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively. Previous researchers used a special method by using special shape as shown in attached figure (black and white figure). I am following the same procedure but could not mesh properly as the figure (green). I have tried by introducing more seeds but then it becomes an un-meshable partition. Can anyone recommend me a method to mesh that part.
RE: Meshing an irregular part in Abaqus
What happens if you change from structured (green) to sweep (yellow) on the problematic partition?
Thanks.
You could maybe try bottom up meshing. It can produce really nice results. Just a suggestion. Link
I do not know how to use infinite elements.
Br,
Thanks a lot.
