Where to start designing a Air Vane Pump?
I want design 7.5 kw air vane pump with 10 m3/hr. But I am stuck where to start.
Do i go shaft--> vane displacement--> rotor --> cam ring --> Casing etc...
as not able to get any literature on same , more centrifugal pump is found.
Suyog Patil
CAD Engineer
NX 7.5. 8, 8.5 9, 10 TC-9
RE: Where to start designing a Air Vane Pump?
First you decide if the pump will run lubricated or dry, then you start selecting a set of materials.
Mike Halloran
Pembroke Pines, FL, USA
It will run dry .. material will steel for shaft rotor and camring and vane (case hardened).
Suyog Patil
CAD Engineer
