Heater via. heat exchanger network
in filed oil processing when we increase heat before crude oil enter separator or De-salter some company use heater (direct or indirect fire ) to increase feed crude oil and other use water / oil heat exchanger and furnace to heat water loop , what is the deference and what is the better
