antenna cable
antenna cable
antenna cable
what is the cable type that i use for connecting antenna and a Terrestrial television or broadcast television(analog)?
there are 3C-2V, 5C-2V, RG 59 and RG 6 cable types. what type of cable should i use?
RE: antenna cable
75-ohm.
RG-59 or RG-6. I've not heard of the others you listed.
RG-6 is thicker and lower loss than RG-59.
RG-6 is usually the default choice.
Think ahead about the connectors. F-type in North America, and may vary in other areas. You might need a crimp tool, which can be very cheap these days.
RE: antenna cable
The F-connector is very common in places (North America), but the 'IEC' connector is used in Europe and Australia.
So it's a geographical and historical variation of TV antenna connectors.
See this: https://en.wikipedia.org/wiki/TV_aerial_plug
I've run into these Belling-Lee connectors because of Software Defined Radio (SDR) USB gadgets. The gadgets were designed for digital TV reception in Europe, but are pressed into SDR service. So we must order various IEC-to-F adapters to make things fit.
