AISC Manual 15th edition release date
Does anyone know with the 15th edition is coming out?
Faith is taking the first step even when you can't see the whole staircase. -MLK
AISC Manual 15th edition release dateAISC Manual 15th edition release date(OP)
Faith is taking the first step even when you can't see the whole staircase. -MLK Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: AISC Manual 15th edition release date
Nearly all men can stand adversity, but if you want to test a man's character, give him power. Abraham Lincoln
Plus, I don't think AISC has that bad of a reputation for Errata...at least with the main steel manual. The SEISMIC Manuals, on the other hand, have been a bit messy. Especially the 1st edition.
A couple of past threads on this:
thread172-287345: Lousy AISC manual - errata errata errata
thread172-246274: AISC Manual Errata
Mike McCann, PE, SE (WA)
"...my office wants to get a head start on implementing the new code before engineers are required by law to have it."
The 15th Edition (or any preceding edition) of the Steel Construction Manual is not required by any law. It's simply a design aid.
The Specification for Structural Steel Buildings (AISC 360) is referenced by the various building codes including the IBC. AISC 360-16 will be embedded in the 15th Edition manual, but it's available for free download and has been for some time, but it won't be in a building code until their next revision, which should be the IBC 2018.
https://www.aisc.org/globalassets/aisc/publications/standards/a360-16-spec-and-commentary.pdf
The 2016 spec is what will required by law. However, there will be clarifications and examples on how to apply the spec in the manual. Not just design aids. That's why the manual is important to us to help us get a head start.
The other point was that it won't even be binding for several years.
On September 15 AISC has a free webinar on this as part of Steel Day: Link:
Also, some significant changes to appendix 1 (Inelastic analysis), but not one really uses that section.
Dik
As the name change implies it covers more than just inelastic analysis now. It allows an extension of the Direct Analysis Method where you can use an unbraced length (for compression strength) of zero. Essentially, you're relying on the analysis to capture all compression buckling effects.
I watched the webinar recommended by Ingenuity. There are a number of changes, for sure...
-5^2 = -25
http://www.eng-tips.com/supportus.cfm
