copy sheet metal part drawing to assembly drawing
Hi everyone,
I have one weldment includes sheet metal bend parts. the requirement is to detail piece parts also in weldment(assembly) drawing. I am able to detail the part in form view by hiding other parts one by one. Now the problem comes when it comes to detail the flat pattern. if I detail the flat pattern under individual part drawing, copy that view and paste it in assembly drawing, it works, till the individual part drawing is open in session, once I close them, open assembly drawing again, the flat view is gone. Is there any way to solve this problem, I know its not a good practice, but I have to follow the lead.
I work on NX/TC 9
Thanks in advance,
Suri
I work on NX/TC 9
Thanks in advance,
Suri
RE: copy sheet metal part drawing to assembly drawing
You should be able to add the flat pattern directly in the assembly drawing. As long as you have created the flat pattern first, click add base drawing then select flat pattern.
