ASME Pressure vessel fabrication.
Hi Guys,
I am still new about pressure vessels. I found we have 3 type of fabrication for pressure vessels 1- welding 2- forging 3- brazed method.
1- What’s the differences between welding and brazed method?
2- In forging method which types of welds are acceptable? Can we have transverse weld and use UF part of the code?
RE: ASME Pressure vessel fabrication.
