Pipe leg support base plate design for two foundation bolts.
RE: Pipe leg support base plate design for two foundation bolts.
Use your engineering experience and design accordingly. Not every calculation you do in engineering can be given in a book to copy!!!!
Can't see your picture. Post a jpg or png file.
Now use 4 bolts.
A 2 bolt base plate isn't a very stable configuration.
'... because pvelite do calculation for 4 bolts as per Deniss Moss..." probably as the author has the same thinking as BI.
Contact Coade? Look in help for the software? Do it by hand?
