How to create a point with reference as Absolute Work using NXOpen Programming?
I want to create a point with reference as "Absolute Work" using NXOpen C++ Programming. When I create a point using NXOpen C++ programming, its reference is set to "WCS". So I cannot move that point in NX once its reference is set to "WCS".sad Also after the point is created programmatically with reference WCS, I try to change the reference to "Absolute Work" in NX but it is not set.surprise
I tried recording journal for creating point with reference as "WCS", but could not figure out any thing from it which would help me.pc3
If anyone has faced this issue and has solution, please help me out.neutral
Yashodeep
RE: How to create a point with reference as Absolute Work using NXOpen Programming?
There is a function that maps(or converts) points(in double array format) from one coordinate system to another. Search MapPoint in the soulution center and you should be able to find a sample.
https://solutions.industrysoftware.automation.siem...
DHuskic
Nx 9.0
