Grout Made with River Water
I am working on a project where diagonal soil anchors are being used to restrain the top of a steel sheet pile bulkhead along a river. The contractor has asked if he can use water from the river as mix water for the grout which will be used in the soil anchors. We had the water tested, and it has a suspended solids concentration of about 13 ppm.
Has anyone done this before? If so, what are your suggestions?
DaveAtkins
RE: Grout Made with River Water
C. Water:
1. Water shall be sampled and tested in accordance with the requirements of AASHTO T 26.
2. Water shall be clean and free from harmful amounts of acids, alkalis, and organic materials.
3. Water shall not contain more than 1,000 parts per million of chlorides as Cl or of sulfates as SO4.
4. Potable water obtained from Public utility distribution lines is acceptable without testing.
5. Additional water other than that specified in the approved mix design, either at the plant, in route or at the site shall not be allowed.
6. Water obtained from Lake _______ may not be used for concrete mixtures without meeting all other quality requirements.
www.PeirceEngineering.com
