Model geometry in drawing file does not show up in drafting views
I work in master model mode in NX9.
When I create a linked body in a drawing file from one of its components, that linked body will not show up in any drafting views when I switch to the drawing.
Is there a setting to enable the display of this linked model geometry in drawing views within the drafting module?
RE: Model geometry in drawing file does not show up in drafting views
-Dave
NX 9, Teamcenter 10
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
This used to work.
I need to have geometry, either curves or solids, which are created in the modeling module within the drawing file to show in any created view when in the drafting module in the same drawing file.
At the top of the add bas view dialog, you can select which part the drawing views you select are from.
OOTB in NX9 it would be the model part. Change to the drawing part and you will see what you are after.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
Thank you everyone for the help.
I will let you know if this works.
Dave C. from Desing Intent.
