Fix positions in Assembly
Hello everybody,
I modelled an assembly within Abaqus CAE which consists out of many single components.
For this, I used many constrains as face2face and so on.
Now, if I change any components due to design changes, I need to either replace or delete the old instance in the assembly.
If I do so, all connected parts obviously lose their constrains and are flying around in space.
Then I have to arrange all of them again.
Therefore the question: is it possible to fix every position of each single part in the assembly, so that even by deleting the given constraints, the position wont change?
kind regards!
RE: Fix positions in Assembly
Assembly-Module: Instance -> Convert Constraints
Abaqus/CAE Users Guide 13.10.11 Converting constraints
perfect, thank you very much!
