Sync file properties from 3D to Draft
I am trying to set up a new file management system for my new employer, they previously had none. I am using Document Number as part number and Title as part name. These fields are being entered in the 3D environment. For searching and ease of use, I would like those properties to sync with the file properties of the draft file. This way, if someone is searching for a part name, they can find the draft. Is there a way to get these two environments to sync their properties?
Thanks!
Thanks!
RE: Sync file properties from 3D to Draft
When editing your draft template (the background sheet), use the CALLOUT function instead of a TEXTBOX.
Within the Callout function, there is a button for inserting PROPERTY TEXT. Use that to link part properties to the face of the drawing.
NOTE: As of ST8, the TEXTBOX function does allow for inserting PROPERTY TEXT, too. After you click to start the location of the text, there is a button on the far right of the Command Bar to insert Symbols, Characters, or Property Text.
--Scott
www.wertel.pro
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Also for reference, my company is running ST5.
Thanks for your responses.
--Scott
www.wertel.pro
