Fin Fan guidance
Fin Fan guidance
Fin Fan guidance
Good morning,
If I have a fin fan bank and want to make 2 out of 1 how would I register them with NBIC as a A & B unit? Will both of these be able to be registered as a U1 or will the B unit only be able to register as a R2
RE: Fin Fan guidance
Questions:
(1) Will the new configuration include the ability to block (valve) off the "A" cell and use only the "B" Cell and vice-versa?
-Or-
(2) Will both "new" cells still work together as one with no isolation valves?
If (1) is correct then you could use the A/B as you suggest.
If (2) is correct then you could still use the existing designation because it is still functionally one exchanger.
There may be other choices for the designations, let's see what others have to say.
Sometimes its possible to do all the right things and still get bad results
