THRU vs. THROUGH
THRU vs. THROUGH
I did a search and could not find any threads talking about this...
So my question is... Can/should "THRU" be used in drawing notes or view titles?
We always have and always will use the spelling "THRU" in the context of a hole note/feature on a part.
In my short 15yrs working with/creating government drawing packages I have never seen the spelling "THROUGH" use in the above instance.
BUT, from time to time I have seen "THROUGH" used in drawing notes. E.G. "...ITEMS -1 THROUGH -16 ARE FOR REFERENCE ONLY..."
I have also seen "THRU" used in that same instance. E.G. "...ITEMS -1 THRU -16 ARE FOR REFERENCE ONLY..."
Grammatically I know in formal writings that "THROUGH" is always supposed to be used over "THRU" with exceptions to popular branding such as "DRIVE-THRU".
In the engineering field, particularly on the government side, is there a right or wrong here? Has it changed over the years? What do you primarily use in both instances discussed above?
THANKS!!
THANKS!!
RE: THRU vs. THROUGH
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Irvine, CA
Siemens PLM:
UG/NX Museum:
Same words, different implications.
Your point TenPenny?
Irvine, CA
Siemens PLM:
UG/NX Museum:
Irvine, CA
Siemens PLM:
UG/NX Museum:
Keith Cress
I was under the impression that an amusing play on words would be amusing in a thread about language. I did not realize that some members were suffering from such a disability that it would cause such a wave of consternation.
Kenat, you aren't normally such a Richard.
Persons from one English speaking region trying to impose their syntax etc. on English speakers from another region without understanding societal norms has been a recurring issue in this forum - so I may have over reacted. Or just been in a bad mood, it happens.
CheckerHater, the largest English-speaking group is definitely the Yanks...I assume we are talking in girth?
high speed image capture, that's me..
Inner layer British English (I'm being generous to places like Newcastle, and offensive to Ireland by throwing them in this category).
Next layer Native English Commonwealth i.e. Australia, New Zealand ...
Next layer mostly Native English Commonwealth with strong second European language influence i.e. South Africa, Canada ...
Then USA English & then the existing illustration.
(It's like the explanations of layers of particles in an atom, the more you look the more layers there are)
Mike McCann, PE, SE (WA)
Er, I meant boot...
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Bill
"Why not the best?"
Jimmy Carter
Since this is a "language/grammar" forum, I feel the need to point out that contrary to popular belief (and most spellcheckers), "irregardless" is not actually a word
Irvine, CA
Siemens PLM:
UG/NX Museum:
