Count unique parts in assembly manually (tip)
I have been looking for this some time and saw more people have this question.
I have found a way how you can do this.
Start visual reporting found under the information button which is between the pallettes at the side of the screen.
Put the report type on Weigth kg
Click on the wrench to edit it
The under report Property put source on "Component Property" and Property on "Desrciptive Part Name"
Press OK
Now every unique part gets its own color and in the info window you can see how many of there are of each part.
And when you click on the name you can even see where they are located in the model.
See also the attachement.
Regards, Michel
Press OK
Regards, Michel
Groeten, Michel
I use NX9.0.0.19
HP Z420 Intel Xeon 3.2GHz
Quadro K4000 3GB
64GB Memory
Windows 7, 64-bit
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
