Import Assembly into TC (Function)
I want to import a big assembly into TC, but I get following error as logfile, after execute.
The following parts experienced naming failures during name application
These failures may have occurred when applying PDM attributes as well as part names
If in doubt, use the Report function to see what
has not been applied
Input for part revision was invalid. - XX2014_SU_XX_ST_SR Connecting Shaft End Outer Shim
Input for part revision was invalid. - XX2014_SU_XX_ST_SR Connecting Shaft End Inner Shim
Input for part revision was invalid. - XX2014_SU_XX_ST_QR Quick Release Trouble Car Assembly
RE: Import Assembly into TC (Function)
I am assuming you have used the user naming instead of autogenerate?
Anyhow...Teamcenter assumes the underscore to be the revision divider. So in case of the first name it assumes you want to have a revision SU
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
I used AutoTranslate. Shortterm SU - Suspension
Same issue...
Autotranslate tries to use the part name (from the part you are importing) and apply that in Teamcenter...
Teamcenter thinks the revision needs to be SU...which is not allowed in your environment
NX9 / TC10.1.2
HP Zbook15
You may need to edit the import.clone file to import the data if you wish to keep the underscores in the item ID.
Mike Hyde
www.astonmartin.com
NX10.0.3 with TC11.2.1 and Vis 11.2
*hmm* but each part name has underscores and there aren't invalid part revisions.
If you create a log file during import this will create an import.clone file which will tell you how it is trying to import each file. It is possible to import files containing underscores as we do here but we create our own import.clone file prior to import.
Mike Hyde
www.astonmartin.com
I think you misunderstand the point...
Teamcenter starts "reading" the partname...It encounters the first underscore and assumes everything behind that is the revision indicator...
SU_XX_ST_SR Connecting Shaft End Outer Shim is not a valid revision in teamcenter.
NX9 / TC10.1.2
HP Zbook15
Parts with underscores in the filename can be imported by modifying the import.clone file for each part. For exaample:-
&LOG Part: "C:\folder\XX2014_SU_XX_ST_SR Connecting Shaft End Outer Shim_1.prt"
&LOG Cloning_Action: DEFAULT_DISP Naming_Technique: DEFAULT_NAMING Clone_Name: @DB/XX2014_SU_XX_ST_SR/1
&LOG Container: "NX_Import"
&LOG Part_Type: "Item"
&LOG Part_Name: "Connecting Shaft End Outer Shim"
&LOG Part_Description: ""
&LOG DB_Owner: tomekzzz TC_Group
&LOG
If this just affects the 3 parts then editing the file shouldn't take too long.
Mike Hyde
www.astonmartin.com
When trying to use the log file option it creates an empty clone file.
You will need to use either the Auto Generate or Auto Translate options. The only way I could get an empty file is use User Number and to cancel when prompted for a name. I presume you are on NX9 or earlier as NX10 makes it much easier to edit Item IDs before importing.
Mike Hyde
www.astonmartin.com
Sadly, we use NX8.5. I tried both options without result (empty file).
I have tried to create an empty clone file in NX8.5 but have not been able to do so. If a part to import is specified, log file name defined and dry run selected then it should create one.
Mike Hyde
www.astonmartin.com
