Chemical Pipeline Design
Hi All,
Looking for some guidance on the best materials to use for Sulfuric Acid pipework transfer, and diluted but low pH mixture. There are two operating conditions:
1) 98% Sulfuric Acid injection to a tank - ambient temp but tank is heated w/steam to approx 90-100 deg C therefore can consider some heat transfer, particularly at the connection point/flange
2) Highly acidic (pH 2) Acid Water and Acid Oil pipelines (following injection of H2S04) at 100 deg C, roughly 5% dilution of sulfuric acid in the mix.
Pipeline velocities <2m/s
For background info the application is an oil soapstock splitting plant
Appreciate any help
Appreciate any help
RE: Chemical Pipeline Design
http://www.eng-tips.com/viewthread.cfm?qid=270320 and
http://www.eng-tips.com/viewthread.cfm?qid=369828
hot, very acidic fluid - Internal plastic type linings won't like it much from the temperature point of view, you're definitely into exotic materials if you don't have a liner.
