NBIC decrease heating surface considered an alteration?
Hello, So in the NBIC Part 3, Examples of Alterations 3.4.3 (d) states that a change in the dimensions or contour of a pressure retaining item constitutes an alteration. (e) states that In a Boiler, an increase in the heating surface or steaming capacity constitutes an alteration.
My question is; If in a fossil fuel boiler, one plugs a tube at a drum or header, and removes the now unused tubing from the boiler, is that considered an alteration? By the same logic, would shortening a loop or bend also be considered an alteration?
RE: NBIC decrease heating surface considered an alteration?
Answer: Yes
Why is this a repair and not also an alteration?
