surface texture
surface texture
Does anyone know of a surface texture which can be obtained for stainless steel to increase heat transfer in condensing heat exchangers?
Michael McGuire
RE: surface texture
Which side (cooling liquid side) or condensing side needs the special (or axtra) heat transfer coefficient?
What chances of contamination or biological growth on either side?
RE: surface texture
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
RE: surface texture
What you need is a hydrosocpic surface so that instead of wetting you get drop wise condensation.
There has been a lot of research and testing in this area. In systems other than steam it is done with additives in the working fluid. There has not been a surface treatment/coating that has yet shown that will hold up long term in a live steam environment.
RE: surface texture
RE: surface texture
Considering that in a steam condenser roughly 30% of the total resistance to heat transfer is related to the water film on the steam side, this becomes the absolute upper limit of heat transfer improvement. Realistically if you capture 75% of this, and increase the flow also it should be possible to see a 20% overall improvement. This has not been demonstrated on an industrial scale. After that durability is the next big question.
RE: surface texture
Virtually all of the steam surface condensers in thermal power plants have bare (non-finned) tubes.
There have been extensive studies by EPRI and others exploring finned and other enhanced surface HXs.
You can be sure that if anyone is intensely interested in wringing the last bit of performance from a steam surface condenser , it is the electric utility industry
Bare tubes are the best
For the design of steam condensing HXs, I suggest you become familiar with the HEI standards ....... and go with a fabricator who has done many of these......
MJCronin
Sr. Process Engineer
