building addition - 5 story wood
I am looking at an expansion for an existing 5 story wood frame structure. (Residential)
The existing doesn't have capacity for additional gravity loads so the structure will need to be independent.
With the effects of settlement (footings) and shrinkage, I am concerned about the differential movement between new and existing.
What details are typically provided at the transition to deal with the movement?
RE: building addition - 5 story wood
Possibly helpful: I had a gap with a steel cover plate and the Architect used a PVC siding product and gaskets to cover for a VERY budget-obsessed client. Ironically the larger the gap in your case the better. Build with some (maybe 2%) slope up to the new building and detail for / live with the eventual reversal of this slope.
That is, however, how I have upgraded both URM and post-disaster structures in the past, so it depends on the case at hand.
