3D hole parameters on 2D design table
Hey folks!
I need to extract some information from 3D holes in order to create a drawing design table.
So, here is the point: I need a table with these parameters: "Diameter", "X", "Y" and "Z".
The command "Hole dimension table" gives the "Diameter", "X" and "Z". It does not return the "Y" values.
The command "Coordinate dimension table" gives the "X", "Y" and "Z". There is no way to include the "Diameter" values.
I've tried to create these two tables in order to "copy/paste" the missing parameters, but the parameter assortment does not match.
Any idea is gonna be welcome!
Thank you in advanced.
RE: 3D hole parameters on 2D design table
Hole tables on drawings are typically used for plates or sheets containing many holes. Since all the holes are located on the same face of the plate/sheet, the third coordinate is the same value for all the holes in the table.
If you absolutely need the third coordinate in the hole table, you could edit the table, insert a new column and then enter the coordinate value manually.
