Unrecognized Adjustable Braces
Hello all,
I'm looking to build an adjustable truss system and am looking for structural pipe braces that have an adjustable length (shown in the attachment). I have seen them on multiple projects and am convinced that they are manufactured in a catalog, but can't find it anywhere. The closest I have found are Dayton tilt-up wall-brace supports, but it's not quite what I require.
Does anyone recognize these things or can point me in the right direction? Thank you!
RE: Unrecognized Adjustable Braces
Whatever you do, I'd choose one from another catalog.
Sorry, can't help you here...
They're quite common in automotive (steering linkage amongst others), but this probably isn't going to help you.
http://www.fusionpoint.be
http://be.linkedin.com/in/fusionpoint
www.SlideRuleEra.net
www.VacuumTubeEra.net
Why not ask some of the contractors involved in that part of the work on the ‘multiple projects’ on which you have seen these used? Maybe ask some of the suppliers who deal with that part of the construction industry in your area? Is that some sort of heavy hung ceiling application in your photo? The top connectors are obviously a proprietary casting of some sort, is there a casting number on them, or any manuf’er. i.d. stamp on the entire piece someplace? I would call these small, light weight, adjustable struts. It would seem that the struts would work in either tension or compression, with some tabulated values vs. strut length in compression.
Stop at a large tractor dealer and look them over.
As far as the other end, there must be a socket type fitting that can be welded on. Smashing it as shown and drilling the hole probably works, but I prefer something I can run numbers on or get the manufacturers rating.
SlideRuleEra: Thanks for the recommendation. Unfortunately this truss system needs to handle BOTH tension and compression loads and therefore I can't rely on a tension-only rod and a compression-only rod.
dhengr: There's no casting number unfortunately. The photo was taken top-down but it's actually a bracing system to hold up a vertical plywood climbing wall. These struts do require to work in both tension and compression which is why turnbuckle rods (the closest thing I could find) won't work.
oldestguy: Thanks for the advice. If worst comes to worst I may have to bring my tension and compression loads and unbraced length to a machine shop and see if they can fabricate something for me with those parameters.
JedClampett: I have also seen "homebrew" creations that use a nut welded to a pipe and a threaded rod for that nut. Did you have any concerns for accidental eccentric compression loads since effectively there's only one point of transfer between the threaded rod and the pipe (the welded nut)?
