Release license while working in NX
Hi All,
We are still on floating licenses (no Mach Bundles). Up to NX6 (I believe) it was possible to release any licenses, you were using in NX, by selecting Ctrl-W shortcut on the keyboard.
NX would go to Gateway making the rest of the licenses available for others...
As of NX7.5 this is no longer possible (as it seems). Is there another way of releasing the licenses you are using without shutting down NX?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
RE: Release license while working in NX
I checked in NX6 and Ctrl+W is for Show/Hide (same as in NX7.5 and later).
No OOTB shortcut exists for Gateway that I could find.
Why not just create a shortcut to automatically send you to Gateway?
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
Quote (PhoeNX)
the objective is not to go to Gateway...(that would be the end result). For me it is important to release all licenses...
To be specific, we have a limited amount of Advanced Assemblies licenses. Currently it is only possible to release such a license (when used) by shutting down the NX session of the user who has the license...This is of course not the best solution..
NX9 / TC10.1.2
HP Zbook15
Making Gateway the application cannot (?) be that frequent command that you need a hotkey ?
Application - Gateway ( or File - Gateway in later versions) should still do the same trick. (?)
Tomas
A lot depends on how the license file is created. If the AA license is tied to a base license, then it cannot be independently released.
Ben Loosli
the advanced assemblies license is like duct tape... I have seen the same issue on this one. We should really open an IR on that.
Tomas
You might be able to release the licence with a journal using this command.
CODE
thesession.LicenseManager.Release("assemblies", Nothing)
We use bundles so I can't test it.
Mike Hyde
www.astonmartin.com
NX10.0.3 with TC11.2.1 and Vis 11.2
If you close all parts, is the license released?
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Quote (markrief)
Nope...need to close the NX session to release it
NX9 / TC10.1.2
HP Zbook15
Stop and restart the license server will release all licenses.
I think there is also a flush command that will kill all license connections with FlexNet.
Ben Loosli
I agree that this is a poor workaround , this issue must be a PR .
Anyway, :
The Lmutil has the option to remove a specific license from a specific user, :
The C:\siemens\flexlem\lmutil ( to be run in a command window, not a graphical user interface)
( lmutil -help prints all the options)
lmutil lmremove [-c licfile] feature user host display
Tomas
Quote (looslib)
Yeah, I think the rest of the users will really like that action.... yawn2
NX9 / TC10.1.2
HP Zbook15
If they are active in NX, the system will just grab anew license when it checks and the users will keep rolling along. In Creo we get a pop-up saying the license as been reestablished, but this can be disabled.
Ben Loosli
