MIL-PRF-85285, POLYURETHANE COATING FLAMMABLE?
Hello all,
Is High-solids Polyurethane coating (MIL-PRF-85285, Type I, Class H)flammable once cured? If yes at what temperature?
I can't find anything in the specs.
thanks,
RE: MIL-PRF-85285, POLYURETHANE COATING FLAMMABLE?
Check the MSDS for that particular coating.
If not found data in MSDS, then perform a DSC temperature decomposition test. Take a polymerized sample to measure the temperature.
