Applicable code for gas pipeline pig traps
According to ASME B31.4 "Scraper traps are to be installed as deemed necessary for good operations. All pipe, valves, fittings, closures, and appurtenances shall comply with appropriate sections of this Code".
Is there any similar indication on the applicable code for gas pipeline? I didn't find any reference within ASME B31.8 for the code to be used in case of pig traps connecting gas pipeline.
thanks
thanks
RE: Applicable code for gas pipeline pig traps
B31.8 requires that pig traps and launchers have an ASME BVP VIII stamp on only quick opening closures. B31.4 I think still does not require the ASME stamp. You should specify a pressure lock be included on the closures which will prevent opening when pressurized.
