Automation Scope Table
I want to make a movement table for a scope. I basically just want two axis movements, one in Z (vertically) and one in Y (Horizontally perpendicular to the user), don't need X movement.
Z movement = 80mm so 40mm up & 40mm down.
Y Movement = 40mm so 20 left & 20 right.
Just wondering are there any off shelf mechanism with motors or actuators and a table (150mm x 150mm square) that I can buy?
The weight on them will be around 15-20 kg and with a SF of 4 they will be about 80kg. The space is a bit tight as above, if nothing works out I am going to use some gears and motors and make the table (hopefully not too expensive).
Any suggestions and advice would be great.
RE: Automation Scope Table
https://www.thorlabs.com/navigation.cfm?guide_id=2...
https://us.misumi-ec.com/vona2/mech/M0500000000/M0...
http://www.igus.co.uk/wpck/10763/DryLin_E_Startpag...
So I think I am gonna have to make something.
http://www.pi-usa.us/products/index.php?onl_goog_p...
http://www.velmex.com/Products/index.html?gclid=CM...
http://www.deltron.com/Micrometer_Positioning_Stag...%
http://us.essentracomponents.com/en-US/search?sear...
