Irregular diaphragm problem
Hi
I have a structure with a irregular distribution i'm using a steel deck like roof
i usually use colector beam in my projects, but in this case, i need other option
i was checking the SDI manual, but in all the examples a collector is the only solution that they use
i want to now your opinion, if i don't use a collector beam, can i consider the restraint like the image for the deck design? maybe some of you had have a case like this thanks in advance
please the attached image
cris
RE: Irregular diaphragm problem
You need to justify the load paths. I recommend collector beams along each grid line where you want to resist lateral loads.
DaveAtkins
What about topping the deck with concrete and designing the collectors with rebar in said topping?
"It is imperative Cunth doesn't get his hands on those codes."
